Hey y’all, I’m working on a project right now that involves using the vex distance sensors as a way to create automatic braking. Right now I have 2 issues: When the robot gets close enough to the wall, it just stops moving. This is likely due to me setting the speed based on division not subtraction. and the second issue is the robot sometimes doesn’t stop at all. My main goal is for the robot to slowly slow down as it gets closer to the wall, but I’m unsure how to have the robot slowdown without impeding the ability to drive backward
Code provided below
type or paste code here/*----------------------------------------------------------------------------*/
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Vision10 vision 10
// Optical9 optical 9
// Distance11 distance 11
// Distance20 distance 20
// Optical19 optical 19
// Controller1 controller
// Drivetrain drivetrain 17, 18
// Motor16 motor 16
#define _USE_MATH_DEFINES
#include <cmath>
#include <math.h>
#include <algorithm>
#include <iostream>
#include "vex.h"
using namespace vex;
competition Competition;
motor lF = motor(PORT6, ratio6_1, true);
motor lM = motor(PORT5, ratio6_1,true);
motor rF = motor(PORT3, ratio6_1, false);
motor rM = motor(PORT2, ratio6_1,false);
motor_group lefts = motor_group(lF,lM);
motor_group rights = motor_group(rF,rM);
drivetrain all = drivetrain(lefts,rights);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton() {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void closer(void)
void far(void)
void skills(void)
void autonomous(void)
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1)
int y = Controller1.Axis3.position(percent);
int x = Controller1.Axis1.position(percent);
int neg = 9998 - Distance20.objectDistance(mm);
if( Distance20.objectDistance(mm) < 0)
neg = 0;
Controller1.Screen.print((Distance20.objectDistance(mm)) );
Controller1.Screen.print(" " );
Controller1.Screen.print(neg );
Controller1.Screen.newLine();
lefts.setVelocity((y+x)/neg , percent);
rights.setVelocity((y-x)/neg, percent);
wait(1,msec);
rights.spin(forward);
lefts.spin(forward);
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
Thank you for any help or advice!
