Auton not working yeah
So we can turn in auton but we can’t drive forward in lock code in auton
Be more specific? Either you set your code to (When Started) and not (When Autonomous), send a photo of your autonomous code so I can help.
I set it to when started because we don’t have VexNet Field control to start auton
I recommend you get one as soon as possible then. The link is here and it’s fairly cheap to get for your schools robotics budget.
I forgot to mention, that I don’t even have a field. The best I can do for a field is drill together 12 foot planks, and use pvc for the steaks
The VEXnet competition switch you linked (sku 276-2335) is discontinued and can no longer be purchased from VEX :​(
That’s a problem. Since the surface from planks (I’m assuming it’s wood) varies from the foam tiles VEX uses.
oh. Is there another way to test autonomous and driver control then?
I guess you could go to the programming skills section of the competition setting
However, my school has an extra vexnet field control switch thingy
I’m using the planks for the field perimeter
