Auton Selector Problems
I’m trying to make an auton selector where you can press different buttons to make different combinations for an auton. The only solution I have thought of is to write a lot of if statements for which button is pushed to then add the function in a sequence, but I was wondering if there was a simpler solution that could produce a bunch of auton combinations without me having to write a bunch of if statements. The buttons work its just the combos that is the problem.
Code is below
Button File
// Button definitions
button buttons[] = {
  {   30,  30, 60, 60,  false, 0xE00000, "Neutral" },
  {  150,  30, 60, 60,  false, 0xE00000, "WP" },
  {  270,  30, 60, 60,  false, 0xE00000, "Rings" },
  {  390,  30, 60, 60,  false, 0xE00000, "Combined" },
  {   30, 150, 60, 60,  false, 0x0000E0, "B1" },
  {  150, 150, 60, 60,  false, 0x0000E0, "B2" },
  {  270, 150, 60, 60,  false, 0x0000E0, "B3" },
  {  390, 150, 60, 60,  false, 0x0000E0, "B4" }
I just included the definitions of the buttons because the rest of the code works
Autons File
void autons(int ){
if(buttons[].state == true){
    n();
Any suggestions would be great
