we are a new team for vex and we have had to do a lot of troubleshooting but are auton will some times stop mid code any ideas?
you know, i have had that happen before, and im guessing it is the connection between the radio and the controller. how to fix this, im not sure. but i do know that has happened before to us. if it happens in a match, i think you can ask for a redo.
i think its just that things dont work perfectly every time. maybe someone else has a idea but im pulling blanks.
Is this for VRC? Or IQ?
If it’s VRC,
Does the controller screen go red?
vrc the conntroller will go red unteal you press home then it will reset the timer
Do you unplug the controller from the computer right before running the auton?
most of the time we unplug it
You might want to checkout this topic, keeping it plugged in might fix it
Basically the controller is disconnecting from the brain because it it changing channels
What about for when it disconnects during a real match?
While you are plugged into the tower controller?
even we plugged into the tower it would some times stop. one time all 4 teams atoun stoped at the same time.
help please state is soon.
That would be something wrong on the tower controller’s end
Does it affect driver control? Or just auton?
it affects both driver and auton.
I can send it too you at about 2:30
Ok, and do the lights on the radio go to solid red when it disconnects or does it turn off?
wait I think I have a picture give me a sec
I think it turns solid red the radio i
