I want to make precise turns with my auton and my inertial sensor but I am having trouble doing it. currently this is my code
double kP = 0.3; // tuning values
//double kI = 3200; //
double kD = 0.2; //
double inertialkP = 0.3; //
//double inertialkI = 0.1; //
double inertialkD = 0.2; //
// default auton settings
int rightdesiredValue = 0;
int leftdesiredValue = 0;
int desiredinertialValue = 0;
// setting variables
int lefterror; // Motor value - desired value :: position
int righterror;
int rightprevError = 0; // previous position 20 ms ago
int leftprevError = 0;
int rightderivative; // error-prevError :: speed
int leftderivative;
int totalError = 0; // total error = totalError + error
int inertialError;
int inertialprevError = 0;
int inertialDerivative;
int inertialTotalError = 0;
double intertialValue;
bool resetDriveSensor = false;
bool resetInertial = false;
bool inertialCorrection = true;
// enable PID
bool enablePID = true;
motor_group LeftMotors(Motor1,Motor2,Motor3);
motor_group RightMotors(Motor4, Motor5, Motor6);
int autoPID() {
while (enablePID) {
if (resetInertial) {
Inertial8.setHeading(0, degrees);
while (resetDriveSensor) {
LeftMotors.setPosition(0,degrees);
RightMotors.setPosition(0,degrees);
int leftmotorvalue = LeftMotors.position(degrees);
int rightmotorvalue = RightMotors.position(degrees);
/* LATERAL MOVEMENT */
lefterror = leftdesiredValue - leftmotorvalue;
righterror = rightdesiredValue - rightmotorvalue;
leftderivative = lefterror - leftprevError;
rightderivative = righterror - rightprevError;
double leftpower = (lefterror*kP + leftderivative * kD)/12.0;
double rightpower = (righterror*kP + rightderivative * kD)/12.0;
Motor1.spin(forward, leftpower , volt);
Motor2.spin(forward, leftpower , volt);
Motor3.spin(forward, leftpower , volt);
Motor4.spin(forward, rightpower , volt);
Motor5.spin(forward, rightpower , volt);
Motor6.spin(forward, rightpower , volt);
leftprevError = lefterror;
rightprevError = righterror;
inertialprevError = inertialError;
vex::task::sleep(20); //refresh
return 1;
int main() {
vexcodeInit();
vex::task autoPid(autoPID);
//auto
resetDriveSensor = true;
resetInertial = true;
rightdesiredValue=-180;
leftdesiredValue=180;
desiredinertialValue = 90;
//continue
//auto
I was thinking to do something like this
if (Inertial8.heading() ! = desiredinertialValue) {
LeftMotors.spin(fwd);
RightMotors.spin(fwd);
