I don’t have all the measurements but this won’t start. It is formatted correctly in the code.
def onauton_autonomous_0():
drivetrain.set_drive_velocity(100, PERCENT)
drivetrain.set_turn_velocity(100, PERCENT)
drivetrain.set_stopping(BRAKE)
ANGLER.set_velocity(100, PERCENT)
ANGLER.set_stopping(HOLD)
drivetrain.drive_for(FORWARD, 1, INCHES)
ANGLER.spin_for(FORWARD, 0, DEGREES)
drivetrain.drive_for(REVERSE, 0, INCHES)
drivetrain.turn_for(LEFT, 0, DEGREES)
ANGLER.spin_for(REVERSE, 0, DEGREES)
drivetrain.turn_for(RIGHT, 0, DEGREES)
drivetrain.drive_for(FORWARD, 0, INCHES)
I need to see the whole program.
Has it been setup to run in competition, this would be a starting point for that.
def pre_auton():
brain.screen.clear_screen()
brain.screen.print("pre auton code")
wait(1, SECONDS)
def autonomous():
count = 0
while True:
brain.screen.print_at("Running Auton... %6d" %(count), x=10, y=60)
count = count + 1
wait(100, MSEC)
def usercontrol():
count = 0
while True:
brain.screen.print_at("Running driver... %6d" %(count), x=10, y=40)
count = count + 1
wait(100, MSEC)
comp = Competition(usercontrol, autonomous)
pre_auton()
Creator: Sawyer Jones
Team: 2011Z Z00M
Model: Conveyer, Angler, Fourbar
Type: AWP 3 Ring Autonomous
def conveyer_forward():
CONVEYER.spin(FORWARD)
def conveyer_reverse():
CONVEYER.spin(REVERSE)
def conveyer_stop():
CONVEYER.stop()
def angler_up():
ANGLER.spin(FORWARD)
def angler_down():
ANGLER.spin(REVERSE)
def angler_stop():
ANGLER.stop()
def fourbar_up():
FOURBAR.spin(FORWARD)
def fourbar_down():
FOURBAR.spin(REVERSE)
def fourbar_stop():
FOURBAR.stop()
def clamp_close():
CLAMP.spin(FORWARD)
def clamp_open():
CLAMP.spin(REVERSE)
def clamp_stop():
CLAMP.stop()
controller_1.buttonL1.pressed(conveyer_forward)
controller_1.buttonL1.released(conveyer_stop)
controller_1.buttonL2.pressed(conveyer_reverse)
controller_1.buttonL2.released(conveyer_stop)
controller_1.buttonR1.pressed(angler_up)
controller_1.buttonR1.released(angler_stop)
controller_1.buttonR2.pressed(angler_down)
controller_1.buttonR2.released(angler_stop)
controller_1.buttonA.pressed(fourbar_up)
controller_1.buttonA.released(fourbar_stop)
controller_1.buttonB.pressed(fourbar_down)
controller_1.buttonB.released(fourbar_stop)
controller_1.buttonUp.pressed(clamp_open)
controller_1.buttonUp.released(clamp_stop)
controller_1.buttonDown.pressed(clamp_close)
controller_1.buttonDown.released(clamp_stop)
drivetrain.set_drive_velocity(100,PERCENT)
drivetrain.set_stopping(COAST)
CONVEYER.set_velocity(75,PERCENT)
CONVEYER.set_stopping(COAST)
ANGLER.set_velocity(100,PERCENT)
FOURBAR.set_velocity(100,PERCENT)
FOURBAR.set_stopping(HOLD)
CLAMP.set_velocity(100,PERCENT)
CLAMP.set_stopping(HOLD)
copy-paste your code in either backticks (```) or code tags [code] [~/code] without the ~
Where are you calling your autonomous function? You have it defined, but you have to call it by
//stuff you want to run
Idk what you mean by copy in backticks or code tags
Just put ``` before and after you copy-paste the code you wrote. This automatically formats it correctly, and makes it easier to read
Team: 2011Z Z00M
CONVEYER.stop()
def angler_up():
def angler_down():
def angler_stop():
ANGLER.stop()
def fourbar_up():
def fourbar_down():
def fourbar_stop():
FOURBAR.stop()
def clamp_close():
CLAMP.spin(FORWARD)
def clamp_open():
CLAMP.spin(REVERSE)
def clamp_stop():
CLAMP.stop()
drivetrain.drive_for(REVERSE, 0, INCHES)’’’
I attempted to but I never did that
The triple backtics at the beginning and end need to go on their own lines.
Your code goes here
and it looks like you used single quotes – the “backtic” character is the key to the left of 1 and above tab on most keyboards.
Or alternately, paste your code in, highlight it all, and click the </>
button.
# Creator: Sawyer Jones
# Team: 2011Z Z00M
# Model: Conveyer, Angler, Fourbar
# Type: AWP 3 Ring Autonomous
CONVEYER.stop()
def angler_up():
def angler_down():
def angler_stop():
ANGLER.stop()
def fourbar_up():
def fourbar_down():
def fourbar_stop():
FOURBAR.stop()
def clamp_close():
CLAMP.spin(FORWARD)
def clamp_open():
CLAMP.spin(REVERSE)
def clamp_stop():
CLAMP.stop()
Thanks that is really helpful
I don’t see the competition template being used. Create a new program that uses the competition template seen in the VEXCode example files, and paste your code in the opcontrol function.
How do you do this Connor
Or anyone that can do it
I showed you yesterday
Oh ok I didn’t know that was what it was called thanks
I will tell you if it works
