autonomous automation
Yes I know, strange title for a thread.
I was asked this question by a student.
So if I understand the question correctly, the idea is to avoid all the sequential calls and have the autonomous instructions in an array. This is essentially what Joseph’s autonomous framework gives you, however, this is quite complicated code so I though I would throw something together very quickly that demonstrates the general idea.
We use a structure to hold the variables needed for each step of the autonomous code.
// structure to hold one autonomous step
typedef struct _auto_step {
    int             number;
    bool            clearEncoder;
    int             count;
    long            timeout;
    autoFunction    func;
} auto_step;
What variables you store are unto you, I have a flag to clear an encoder, a “count” used for moving a number of encoder counts or for a wait delay, a timeout used to abort the driving step, and some function to execute that I have made a new type for “autoFunction”. This can be one of the following enumerated types.
// Different autonomous things we can do
typedef enum _autoFunction {
    kAutoInitialize = 0,
    kAutoStop,
    kAutoDrive,
    kAutoDelay
} autoFunction;
I only have three functions, drive a number of encoder counts, stop motors and wait some number of milliseconds.
To store all the steps in my autonomous code I use an array of this structure.
// We don't have initialized structures (apparently)
// it would be easier to set this as an initialized array
#define MAX_STEPS   10
auto_step   auto_1[MAX_STEPS];
Now ideally, we would just initialize this array with constants, however, ROBOTC won’t let you do that (still) so we have to populate the array in code.
Here is the full example, it’s for a simple 2 motor drive with one IME.
#pragma config(Sensor, I2C_1,  ,               sensorQuadEncoderOnI2CPort,    , AutoAssign)
#pragma config(Motor,  port1,            ,             tmotorVex393_HBridge, openLoop, encoderPort, I2C_1)
#pragma config(Motor,  port10,           ,             tmotorVex393_HBridge, openLoop)
/*                        Copyright (c) James Pearman                          */
/*                                   2014                                      */
/*                            All Rights Reserved                              */
/*    Module:     auto_test.c                                                  */
/*    Author:     James Pearman                                                */
/*    Created:    8 Oct 2014                                                   */
/*    This program is free software: you can redistribute it and/or modify     */
/*    it under the terms of the GNU General Public License as published by     */
/*    the Free Software Foundation, either version 3 of the License, or        */
/*    (at your option) any later version.                                      */
/*    This program is distributed in the hope that it will be useful,          */
/*    but WITHOUT ANY WARRANTY; without even the implied warranty of           */
/*    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the            */
/*    GNU General Public License for more details.                             */
/*    You should have received a copy of the GNU General Public License        */
/*    along with this program.  If not, see <http://www.gnu.org/licenses/>.    */
/*    The author can be contacted on the vex forums as jpearman                */
/*    or electronic mail using jbpearman_at_mac_dot_com                        */
/*    Mentor for team 8888 RoboLancers, Pasadena CA.                           */
    kAutoStop,
    kAutoDrive,
    kAutoDelay
} autoFunction;
    int             number;
    bool            clearEncoder;
    int             count;
    long            timeout;
    autoFunction    func;
} auto_step;
// Add a new step to the autonomous instruction array
void
addAutoStep( auto_step *theAuto, bool clearEncoder, int count, long timeout, autoFunction func )
    int nextIndex;
    // First step should be initialize, this clears the counter in the first step we use
    // to know how many steps we have
    if( func == kAutoInitialize )
        theAuto[0].number = 0;
    nextIndex = theAuto 0 ].number;
    theAuto nextIndex ].clearEncoder = clearEncoder;
    theAuto nextIndex ].count        = count;
    theAuto nextIndex ].timeout      = timeout;
    theAuto nextIndex ].func         = func;
    theAuto 0 ].number++;
// Call this with each autonomous step
void
runAutoStep( auto_step *theAuto, int index  )
    long     timeNow = nSysTime;
    auto_step   *p = &theAuto index ];
    if( p->clearEncoder )
        nMotorEncoder port1 ] = 0;
    switch( p->func )
        // Init function
        // reset gyro etc.
        case    kAutoInitialize:
            break;
        // A delay function
        case    kAutoDelay:
            wait1Msec( p->count );
            break;
        // Stop function
        case    kAutoStop:
            motor port1  ] = 0;
            motor port10 ] = 0;
            break;
        // Drive function
        case    kAutoDrive:
            if( p->count > nMotorEncoder port1 ] )
                motor port1  ] = 100;
                motor port10 ] = 100;
                // Wait until the encoder count is reached or the timeout occurs
                while( (nMotorEncoder port1 ] < p->count) && ((nSysTime - timeNow) < p->timeout) )
                    wait1Msec(10);
            else
            if( p->count < nMotorEncoder port1 ] )
                motor port1  ] = -100;
                motor port10 ] = -100;
                while( (nMotorEncoder port1 ] > p->count) && ((nSysTime - timeNow) < p->timeout) )
                    wait1Msec(10);
            break;
        default:
            break;
// Main task
task main()
    int     steps;
    int     i;
    // Setup autonomous instructions
    addAutoStep( auto_1, true,     0,    0, kAutoInitialize );
    addAutoStep( auto_1, true,  1000, 5000, kAutoDrive );
    addAutoStep( auto_1, false,    0,    0, kAutoStop );
    addAutoStep( auto_1, false,  500,    0, kAutoDelay );
    addAutoStep( auto_1, true, -1000, 5000, kAutoDrive );
    // Number of steps
    steps = auto_1[0].number;
    // run the autonomous steps
    for(i=0;i<steps;i++)
        runAutoStep( auto_1, i );
    // Done
    while(1)
        wait1Msec(10);
Code written for ROBOTC V4.XX, may or many not work in V3.X
Cool, sounds like a neat way to sort of get away from the traditional format of programming autonomous routines. I’ll have to fully read through Joseph’s project sometime. Thanks for posting this
