The autonomous code is to unfold an arm on the robot. It expands up using pneumatics and then 2 motors “ElbowMotor” 1 and 2 lift the arm up to ready position. The problem is the second motor is not being recognized in the autonomous code, however the motor works fine in the user control.
task autonomous()
{ //Initial unfolding code
SensorValue[Solenoid1] = 1;
SensorValue[Solenoid2] = 1;
wait1Msec(1000);
while(SensorValue[Quad] > -430) //if the arm is folded/less than desired spot
motor[ElbowMotor1] = -127;
motor[ElbowMotor2] = -127; //will not recognize this motor
if(SensorValue[Quad] == -430) //if it has reached desired spot
SensorValue[Solenoid1] = 0;
SensorValue[Solenoid2] = 0;
motor[ElbowMotor1] = 0;
motor[ElbowMotor2] = 0;
while(SensorValue[POT] < 1130) //head motor/game piece lift
motor[WristMotor1] = -40;
motor[WristMotor2] = -40;
