I am using a sample program for the IME’s:
#pragma config(Sensor, I2C_1, rightIME, sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_2, leftIME, sensorNone)
#pragma config(Motor, port1, backRightMotor, tmotorVex393HighSpeed, openLoop)
#pragma config(Motor, port2, backRightMidMotor, tmotorVex393HighSpeed, openLoop, reversed)
#pragma config(Motor, port3, frontRightMotor, tmotorVex393HighSpeed, openLoop, reversed, encoder, encoderPort, I2C_1, 1000)
#pragma config(Motor, port4, backLeftMidMotor, tmotorVex393HighSpeed, openLoop, reversed)
#pragma config(Motor, port5, topLeft, tmotorVex393, openLoop)
#pragma config(Motor, port6, frontLeftMotor, tmotorVex393HighSpeed, openLoop, reversed, encoder, encoderPort, I2C_1, 1000)
#pragma config(Motor, port7, topRight, tmotorVex393, openLoop)
#pragma config(Motor, port8, intakeLeft, tmotorVex393, openLoop)
#pragma config(Motor, port9, intakeRight, tmotorVex393, openLoop, reversed)
#pragma config(Motor, port10, backLeftMotor, tmotorVex393HighSpeed, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
/*+++++++++++++++++++++++++++++++++++++++++++++| Notes |++++++++++++++++++++++++++++++++++++++++++++++
Move Forward and Backward - 393 Motors
This program instructs your robot to move forward at half power for 1000 encoder counts, then reverse
at half power for 1000 encoder counts. There is a two second pause at the beginning of the program.
Robot Model(s): Modified Squarebot
* [Name] [Type] [Description]
Motor Port 1 rightMotor 393 Motor Right side motor
Motor Port 10 leftMotor 393 Motor Left side motor, Reversed
I2C_1 rightIEM Integrated Encoder Encoder mounted on rightMotor
I2C_2 leftIEM Integrated Encoder Encoted mounted on leftMotor
task main
wait1Msec(2000);
//Clear the encoders associated with the left and right motors
nMotorEncoder[frontRightMotor] = 0;
nMotorEncoder[frontLeftMotor] = 0;
//While less than 1000 encoder counts of the right motor
while(nMotorEncoder[frontLeftMotor] < 1000)
//Move forward at half power
motor[frontRightMotor] = 63;
motor[backRightMotor] = 63;
motor[backRightMidMotor] = 63;
motor[frontLeftMotor] = 63;
motor[backLeftMotor] = 63;
motor[backLeftMidMotor] = 63;
while(nMotorEncoder[frontRightMotor] > -1000)
//Move in reverse at half power
motor[frontRightMotor] = -63;
motor[backRightMotor] = -63;
motor[backRightMidMotor] = -63;
motor[frontLeftMotor] = -63;
motor[backLeftMotor] = -63;
motor[backLeftMidMotor] = -63;
Now this works, but when I integrate it into a competition template only the forward part works the reverse part never stops when it needs to. This is the code I have for the competition template:
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include "Vex_Competition_Includes.c" //Main competition background code...do not modify!
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
// Insert user code here.
wait1Msec(2000);
while(nMotorEncoder[frontLeftMotor] < 500)
//AutonomousCodePlaceholderForTesting(); // Remove this function call once you have "real" code.
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
while (true)
// This is the main execution loop for the user control program. Each time through the loop
// your program should update motor + servo values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to update your motors, etc.
UserControlCodePlaceholderForTesting(); // Remove this function call once you have "real" code.
I do not know what I am doing wrong, I would appreciate if someone could help me out. Thank You.*
