Autonomous is not running
We have been running autonomous for a while now and now all of a sudden, its not running. There are no errors appearing on the screen. I don’t know whats wrong.
If you can describe the issue more clearly, that will be more helpful!
The problem could be due to the program not uploading successfully.
In some cases, the error can show up on the Brain’s display screen or in the computer logs.
In V5 (mainly C++), you could try:
  • Rebuilding the program (delete build files, then build & download the program)
  • Resetting the controller (instructions here) then re-downloading
You could also post your code here, either with a screenshot (for block coding) or by typing (```) in the line before you paste your code
if it is in text like this
