I’ve been working on an autonomous program in easyC, and I’ve found the blocks MotorTimeControl and MultiMotorTimeControl. These commands should be able to do most of the work I need, but they limit the number of motors that can be moving at one time to 4. Is there a way to remedy this? If I cannot find a solution or an alternative that allows simultaneous control of 6 motors, I will be forced to redesign.
Just use the individual set motor commands and then the wait commands.
You DO NOT need to redesign.
Use motor mod with a wait time then a stop for each motor DONT REDESIGN
Thank you for your help.
