Hi, our team is about to have competition this Saturday and our robot won’t run its autonomous. The driving works so its not technical. The robot would only run the rollers and the half of the driving code before stopping. This is in a competition template and I’m using it without the comp switch, although I don’t know if that information would help.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// rollers motor_group 9, 12
// DigitalOutH digital_out H
// DigitalOutF digital_out F
// Spnrs motor_group 6, 7
// R1 motor 10
// R2 motor 20
// R3 motor 17
// L1 motor 3
// L2 motor 1
// L3 motor 11
#include "vex.h"
using namespace vex;
competition Competition;
//drive (do tank drive)
void left_drive(void){
L1.spin(forward, Controller1.Axis3.position(), velocityUnits::pct);
L2.spin(forward, Controller1.Axis3.position(), velocityUnits::pct);
L3.spin(forward, Controller1.Axis3.position(), velocityUnits::pct);
void right_drive(void){
R1.spin(forward, Controller1.Axis2.position(), velocityUnits::pct);
R2.spin(forward, Controller1.Axis2.position(), velocityUnits::pct);
R3.spin(forward, Controller1.Axis2.position(), velocityUnits::pct);
void spiny_thingys(void){
Spnrs.spin(directionType::fwd, Controller1.ButtonR1.pressing(), percentUnits::pct);
Spnrs.spin(directionType::rev, Controller1.ButtonR2.pressing(), percentUnits::pct);
//ring launcher
int pneu() {
return 0;
void out() { //wherever you write 'out' in the code, you are setting the solenoid to true and it will extend
DigitalOutH.set(true);
DigitalOutF.set(true); //this is the solenoid
void retract() {
DigitalOutH.set(false);
DigitalOutF.set(false);
//rollers
void rollers_config(void){
if(Controller1.ButtonUp.pressing()){
rollers.spin(vex::directionType::fwd, 50, vex::velocityUnits::pct);
else if (Controller1.ButtonDown.pressing()){
rollers.spin(directionType::rev, 50, velocityUnits::pct); //meaning it will reverse at 100 percent speed
else{
rollers.stop(brakeType::hold);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
//setVelocity
R1.setVelocity(70, percentUnits::pct);
R2.setVelocity(70, percentUnits::pct);
R3.setVelocity(70, percentUnits::pct);
L1.setVelocity(70, percentUnits::pct);
L2.setVelocity(70, percentUnits::pct);
L3.setVelocity(70, percentUnits::pct);
rollers.setVelocity(60, percentUnits::pct);
// 1) Backup + Roll
R1.spinFor(reverse, 1, turns, false);
R2.spinFor(reverse, 1, turns, false);
R3.spinFor(reverse, 1, turns, false);
L1.spinFor(reverse, 1, turns, false);
L2.spinFor(reverse, 1, turns, false);
L3.spinFor(reverse, 1, turns);
rollers.spinFor(fwd, 2, seconds);
// 2) Drive + Turn
R1.spinFor(fwd, 1, turns, false);
R2.spinFor(fwd, 1, turns, false);
R3.spinFor(fwd, 1, turns, false);
L1.spinFor(fwd, 1, turns, false);
L2.spinFor(fwd, 1, turns, false);
L3.spinFor(fwd, 1, turns);
/*R1.spinFor(fwd, 1, turns, false);
L1.spinFor(fwd, -2, turns, false);
L2.spinFor(fwd, -2, turns, false);
L3.spinFor(fwd, -2, turns);
// 3) Drive + Roll + Backup
R1.spinFor(fwd, 3, turns, false);
R2.spinFor(fwd, 3, turns, false);
R3.spinFor(fwd, 3, turns, false);
L1.spinFor(fwd, 3, turns, false);
L2.spinFor(fwd, 3, turns, false);
L3.spinFor(fwd, 3, turns);
// 4) Turn + Drive
R1.spinFor(fwd, 6, turns, false);
R2.spinFor(fwd, 6, turns, false);
R3.spinFor(fwd, 6, turns, false);
L1.spinFor(fwd, 6, turns, false);
L2.spinFor(fwd, 6, turns, false);
L3.spinFor(fwd, 6, turns);
// 5) Turn + Drive
R1.spinFor(fwd, 8, turns, false);
R2.spinFor(fwd, 8, turns, false);
R3.spinFor(fwd, 8, turns, false);
L1.spinFor(fwd, 8, turns, false);
L2.spinFor(fwd, 8, turns, false);
L3.spinFor(fwd, 8, turns);
// 6) Turn + Backup + Roll
R1.spinFor(reverse, 2, turns, false);
R2.spinFor(reverse, 2, turns, false);
R3.spinFor(reverse, 2, turns, false);
L1.spinFor(reverse, 2, turns, false);
L2.spinFor(reverse, 2, turns, false);
L3.spinFor(reverse, 2, turns);
// 7) Drive + Turn
R1.spinFor(fwd, 2, turns, false);
R2.spinFor(fwd, 2, turns, false);
R3.spinFor(fwd, 2, turns, false);
L1.spinFor(fwd, 2, turns, false);
L2.spinFor(fwd, 2, turns, false);
L3.spinFor(fwd, 2, turns);
// 8) Drive + Roll + Backup
L3.spinFor(reverse, 2, turns);*/
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
vexcodeInit();
//set stopping hold
R1.setStopping(brakeType::hold);
R2.setStopping(brakeType::hold);
R3.setStopping(brakeType::hold);
L1.setStopping(brakeType::hold);
L2.setStopping(brakeType::hold);
L3.setStopping(brakeType::hold);
//intake.setStopping(brakeType::hold);
//set velocity
R1.setVelocity(100, percentUnits::pct);
R2.setVelocity(100, percentUnits::pct);
R3.setVelocity(100, percentUnits::pct);
L1.setVelocity(100, percentUnits::pct);
L2.setVelocity(100, percentUnits::pct);
L3.setVelocity(100, percentUnits::pct);
rollers.setVelocity(45, percentUnits::pct);
// drive config
right_drive();
left_drive();
// intake config
rollers_config();
// ring launcher config
Controller1.ButtonL1.pressed(out);
Controller1.ButtonL2.pressed(retract);
wait(15,msec);
pneu();
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
