Me and my team have been working on our autonomous programming, and although our code looks okay, we can’t figure out why it seems to be messing up. I have attached it, and any help is appreciated since we do have a sompetition tomorrow morning. (For more context, our auton consists of our bot starting on the roller, spinning the roller, driving uo the center line, turning, and shooting into the high goal.)
/ Module: main.cpp /
/ Author: VEX /
/ Created: Thu Sep 26 2019 /
/ Description: Competition Template /
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// RightFront motor 1
// RightBack motor 4
// LeftFront motor 10
// LeftBack motor 6
// FlyWheelRight motor 11
// FlyWheelLeft motor 18
// Indexer motor 20
// Intake motor 5
#include “vex.h”
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions /
/ You may want to perform some actions before the competition starts. /
/ Do them in the following function. You must return from this function /
/ or the autonomous and usercontrol tasks will not be started. This /
/ function is only called once after the V5 has been powered on and /
/ not every time that the robot is disabled. /
void pre_auton(void) {
vexcodeInit();
// Example: clearing encoders, setting servo positions, …
/ Autonomous Task /
/ This task is used to control your robot during the autonomous phase of /
/ a VEX Competition. /
/ You must modify the code to add your own robot specific commands here. /
///Autonomous Codes///
void autonomous(void) {
///Intake Codes///
Indexer.setVelocity(100, percent);
RightFront.setVelocity(100, percent);
RightBack.setVelocity(100, percent);
LeftFront.setVelocity(100, percent);
LeftBack.setVelocity(100, percent);
FlyWheelLeft.setVelocity(100, percent);
FlyWheelRight.setVelocity(100, percent);
Intake.setVelocity(100, percent);
//Intake Code//
Intake.startRotateFor(vex::directionType::rev, 300, vex::rotationUnits::deg);
wait(0.3, sec);
///Reverse Codes///
LeftFront.startRotateFor(vex::directionType::rev, 125, vex::rotationUnits::deg);
LeftBack.startRotateFor(vex::directionType::rev, 125, vex::rotationUnits::deg);
RightFront.startRotateFor(vex::directionType::rev, 125, vex::rotationUnits::deg);
RightBack.startRotateFor(vex::directionType::rev, 125, vex::rotationUnits::deg);
wait(0.5, sec);
///180 Turn///
LeftFront.startRotateFor(vex::directionType::fwd, 150, vex::rotationUnits::deg);
LeftBack.startRotateFor(vex::directionType::fwd, 150, vex::rotationUnits::deg);
RightFront.startRotateFor(vex::directionType::rev, 150, vex::rotationUnits::deg);
RightBack.startRotateFor(vex::directionType::rev, 150, vex::rotationUnits::deg);
wait(0.5, sec);
LeftFront.startRotateFor(vex::directionType::fwd, 455, vex::rotationUnits::deg);
LeftBack.startRotateFor(vex::directionType::fwd, 455, vex::rotationUnits::deg);
RightFront.startRotateFor(vex::directionType::fwd, 455, vex::rotationUnits::deg);
RightBack.startRotateFor(vex::directionType::fwd, 455, vex::rotationUnits::deg);
wait(0.5, sec);
LeftFront.startRotateFor(vex::directionType::rev, 1300, vex::rotationUnits::deg);
LeftBack.startRotateFor(vex::directionType::rev, 1300, vex::rotationUnits::deg);
RightFront.startRotateFor(vex::directionType::fwd, 1300, vex::rotationUnits::deg);
RightBack.startRotateFor(vex::directionType::fwd, 1300, vex::rotationUnits::deg);
wait(0.5, sec);
wait(0.5, sec);
FlyWheelLeft.startRotateFor(vex::directionType::fwd, 5000, vex::rotationUnits::deg), FlyWheelRight.startRotateFor(vex::directionType::fwd, 5000, vex::rotationUnits::deg), Indexer.startRotateFor(vex::directionType::fwd, 1300, vex::rotationUnits::deg);
/ User Control Task /
/ This task is used to control your robot during the user control phase of /
void usercontrol(void) {
while (1) {
///Motor Velocity codes///
///Motor/Drive Codes///
LeftFront.spin(vex::directionType::rev, Controller1.Axis3.position() + Controller1.Axis1.position(), vex::velocityUnits::pct);
LeftBack.spin(vex::directionType::rev, Controller1.Axis3.position() + Controller1.Axis1.position(), vex::velocityUnits::pct);
RightFront.spin(vex::directionType::fwd, Controller1.Axis3.position() - Controller1.Axis1.position(), vex::velocityUnits::pct);
RightBack.spin(vex::directionType::fwd, Controller1.Axis3.position() - Controller1.Axis1.position(), vex::velocityUnits::pct);
///Velocity Shift Codes///
///FlyWheel Codes///
if(Controller1.ButtonL1.pressing()) FlyWheelLeft.setVelocity(100,percent) , FlyWheelRight.setVelocity(100,percent) , FlyWheelRight.spin(vex::directionType::fwd) , FlyWheelLeft.spin(vex::directionType::rev);
else if(Controller1.ButtonL2.pressing()) FlyWheelLeft.setVelocity(65,percent) , FlyWheelRight.setVelocity(65,percent) , FlyWheelRight.spin(vex::directionType::fwd) , FlyWheelLeft.spin(vex::directionType::rev);
else FlyWheelRight.stop(vex::brakeType::brake),FlyWheelLeft.stop(vex::brakeType::brake);
///Indexer Code///
if(Controller1.ButtonR1.pressing()) Indexer.spin(vex::directionType::fwd);
else Indexer.stop(vex::brakeType::brake);
///Intake Codes///
if(Controller1.ButtonR2.pressing()) Intake.spin(vex::directionType::fwd);
else Intake.stop(vex::brakeType::brake);
Intake.setVelocity(100,percent);
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
