Has anyone had any luck using 2 LEDs as a sequence selection? I am thinking about 1 LED as our ‘Go’ button and a second LED that would essentially reload the sequence in case the program was not successful.
i.e.
Hit Go LED - First step successful!
Hit Go LED - Begins second step
or
Hit Go LED - First step not successful
Hit 2nd LED - Repeats First step, this time it is successful
I can’t quite figure out the looping required. Thinking that using a forever loop, some waits and a break command may get there.
Hit Go LED - Second step begins
What are you programming in? VexCode? RMS? RobotC Text? RobotC graphical?
I made a example program in RobotC graphical. It should be easy to port into your language.
The code. (Unzip Me).zip
Using VexCode IQ Blocks as per the forum.
Thanks for the sample, I will see if we can port it to our language.
Oh, sorry. I don’t have VEX vide blocks, so I can’t give you a demo project for it though…
No worries, this is a good start. I will let you know how it goes
Do you understand what every line in the code is for? If not ask me
I don’t think many of the blocks you used are in VEXCode Blocks
Yes, but the point is the same, and different blocks could be used, that do the same thing. If you want to know what a block does, ask.
