Hey everyone,
My team has our final competition this Saturday, and we are trying to get our WP autonomous to work. However, whenever we try to get the robot to turn, it doesn’t turn properly, and it seems as if something is preventing the robot from finishing the full turn.
For context, when running autonomous, even when the robot seemingly stops, when we lift up the chassis, the wheels spin perfectly fine.
We have tried changing the velocities, tuning down the turning, and adding additional wait times in between each task.
Is there anything that could be done to fix this problem? For example, should we add a timeout between each step?
Side Note: Just in case this helps, we have a four motor tank drive with each wheel geared to a 3/5 ratio (output/input).
Thank you so much!
Here is our program:
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// bclaw motor 21
// Claw motor 16
// bLeft motor 19
// fLeft motor 20
// fRight motor 18
// bRight motor 17
// larm motor 12
// rarm motor 2
#include "vex.h"
#include "VisionSensor.h"
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
//global statements (T-T)
void dt(int pos, int speed, bool stopping) {
bRight.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, false);
fRight.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, false);
fLeft.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, stopping);
bLeft.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, stopping);
void rd(int pos, int speed, bool stopping) {
void ld(int pos, int speed, bool stopping) {
bLeft.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, false);
//changed stopping to false, possible fix
fLeft.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, false);
void Arm(int pos, int speed, bool stopping) {
rarm.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, stopping);
larm.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, stopping);
//rotates the claw
void cm(int pos, int speed, bool stopping) {
Claw.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, stopping);
void bcm(int pos, int speed, bool stopping) {
bclaw.rotateFor(pos, rotationUnits::deg, speed, velocityUnits::pct, stopping);
void autonomous(void) {
//TASK 1 - Dispenses the ring from the back claw
bcm(600, 80, true);
bcm(-600, 80, true);
//TASK 2 - Drives forward
dt(110, 90, true);
//TASK 3 - Turns left
ld(500, 70, false);
rd(-500, 70, false);
//TASK 4 - Drives Forward one block
dt(110, 50, true);
//TASK 5 - Turns Left to Reposition
ld(500, 95, false);
rd(-500, 50, false);
//TASK 6 - Zooms across the field
dt(2300, 110, true);
//TASK 7 - Dispenses ring from front claw
dt(90, 20, true);
cm(450, 80, true);
//TASK 8 - Drives out of the awl
dt(-350, 100, true);
wait(20, msec);
/* User Control Task */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
bLeft.spin(vex::directionType::fwd, Controller1.Axis3.position(), vex::velocityUnits::pct);
fLeft.spin(vex::directionType::fwd, Controller1.Axis3.position(), vex::velocityUnits::pct);
fRight.spin(vex::directionType::fwd, Controller1.Axis2.position(), vex::velocityUnits::pct);
bRight.spin(vex::directionType::fwd, Controller1.Axis2.position(), vex::velocityUnits::pct);
wait(20, msec);
if (Controller1.ButtonL1.pressing()){
Claw.spin(directionType::fwd, 95, velocityUnits::pct);
else if (Controller1.ButtonL2.pressing()){
Claw.spin(directionType::rev, 95, velocityUnits::pct);
else{
Claw.stop(brakeType::brake);
if (Controller1.ButtonUp.pressing()){
bclaw.spin(directionType::fwd, 95, velocityUnits::pct);
else if (Controller1.ButtonDown.pressing()){
bclaw.spin(directionType::rev, 95, velocityUnits::pct);
else{
bclaw.stop(brakeType::brake);
if(Controller1.ButtonR1.pressing()){
larm.spin(directionType::fwd, 90, velocityUnits::pct);
rarm.spin(directionType::fwd, 90, velocityUnits::pct);
else if(Controller1.ButtonR2.pressing()){
larm.spin(directionType::rev, 90, velocityUnits::pct);
rarm.spin(directionType::rev, 90, velocityUnits::pct);
else if(!Controller1.ButtonUp.pressing() && !Controller1.ButtonDown.pressing() && !Controller1.ButtonB.pressing() && !Controller1.ButtonX.pressing()){
larm.stop(brakeType::brake);
rarm.stop(brakeType::brake);
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
