Autonomous stops after 10 seconds
HI there,
We are having issues with our robot stopping after 10 seconds of use, it worked fine for weeks, but just recently (of course before a tournament) it started to not work properly.
Is there somewhere to clear the cache or something? Sorry if this is a newb question. I’ve already wiped the brain, any other ideas?
We’re using Vex Coding Studio if that helps.
If this is only in auton, check to see if there is a misplaced/unneeded sleep function blocking the code. I’ll take a look at the code if you’re comfortable sending it.
messaged you directly
Vexcode is the new version of VCS it’s much easier to use. Vex may soon no longer provide support for VCS, and will likely move onto Vexcode.
