During the autonomous. You want to do the AWP. It says you need to have “a minimum of two (2) Stakes on the Alliance’s side of the Autonomous Line with at least (1) ring of the Alliance’s color Scored.” Isn’t there already 2 steaks on your side. So doesn’t that mean you already have the two. Your opponent can’t go on the other side during the 15sec autonomous. So what does it really mean…?
It means you need at least 1 ring scored on EACH of them
There must be two stakes are your side of the field that have a ring scored on them. I believe you are confusing the wording to mean two stakes on your side of the field, and one scored ring, which is incorrect (although VEX has left this somewhat ambiguous).
Thank you for your help.
