Bad Joystick
We were upgrading the firmware to the newest versions using RobotC 3.63. The cortex updated normal, but the when the joystick was done, the download failed, and when done a second time, the download froze up. Now when the Joystick is connected to the computer, or turned on, all of the lights are red except for the robot light. The computer does not recognize it when it is connected and a vexnet 2.0 key does not have the blue light on/flickering when attached. I have also tried holding the config button but that did not help.
I am guessing the joystick is “bricked” and if so, can anything be done?
EDIT: A second joystick done with the same setup worked normally.
I got it working. I did not realize that the config button had to be held down when the controller turned on, so when I did that it worked.
