I have a ball loading question: Can you load your 20 extra preload balls on to your robot if the robot has left the lifting zone/it’s starting position, assuming you’re not touching any field components?
as long as your robot is touching the loading zone you can load balls into it, so long as the place you are placing the balls is inside the loading zone.
This is true no matter where your robot has moved, or if it is touching field components or not
for example, our first robot sat entirely out side the loading zone, however our intake rollers stuck into the loading zone, and we loaded the balls into it from there
You can load balls into any part of the robot as long as any other part of the robot is touching the loading zone. You could theoretically load a ball onto your robot at any point in the climbing zone if your robot had expanded horizontally (which is legal within the climbing zone).
This is allowed if you load the ball onto the tile and the robot picks it up, but you may not load a ball onto a robot that is overhanging the loading zone if it is not touching the loading zone.
Then we were given a picture for clarification.
Here it is
Here it is seen that the ball was loaded outside the loading zone but the robot was touching the loading zone.
The intent of this rule is to allow teams to introduce objects into play, but not to impart energy
on the Scoring Object which will cause it to end up in a position outside the Loading Zone.
by placing the ball onto a robot which is outside of the loading zone, or by using your hand to move a ball outside the loadingzone you are clearly moving the ball in a way “which will cause it to end up in a position outside the Loading Zone” which is clearly in violation of the rule, but the picture shows that this would be legal, so which verison is right?
I think it was talking about rolling the balls outside the loading zone.
In our previous competition the refs have allowed us to place balls anywhere on the robot as long as part of it was touching the loading zone.
