I just downloaded pros and opened up a template, and I’m getting an error saying ‘main.h’ file not found in the #include “main.h” line.
#include “main.h”
Runs the operator control code. This function will be started in its own task
with the default priority and stack size whenever the robot is enabled via
the Field Management System or the VEX Competition Switch in the operator
control mode.
If no competition control is connected, this function will run immediately
following initialize().
If the robot is disabled or communications is lost, the
operator control task will be stopped. Re-enabling the robot will restart the
task, not resume it from where it left off.
void opcontrol() {
pros::Controller master(pros::E_CONTROLLER_MASTER);
pros::Motor left_mtr(1);
pros::Motor right_mtr(2);
while (true) {
pros::lcd::print(0, “%d %d %d”, (pros::lcd::read_buttons() & LCD_BTN_LEFT) >> 2,
(pros::lcd::read_buttons() & LCD_BTN_CENTER) >> 1,
(pros::lcd::read_buttons() & LCD_BTN_RIGHT) >> 0);
int left = master.get_analog(ANALOG_LEFT_Y);
int right = master.get_analog(ANALOG_RIGHT_Y);left_mtr = left; right_mtr = right; pros::delay(20);
