Basic Pros Drive
After messing around with PROS IDE a bit, I made a couple of programs, the main one that I wanted to check that I was doing right was controlling motors using the joysticks.
Is it in any way possible that someone could send me a basic tank drive code to check off some of my code?
Thanks a ton!
#include "main.h"
void lDriveSet(int control){
	motorSet(2, control);
	motorSet(1, -control);
void rDriveSet(int control){
	motorSet(9, -control);
	motorSet(10, control);
void operatorControl() {
	while (true)
		//set drive motors with a deadband of 5
		if(abs(joystickGetAnalog(1,3)) > 5)
			lDriveSet(joystickGetAnalog(1,3));
		else
			lDriveSet(0);
		if(abs(joystickGetAnalog(1,2)) > 5)
			rDriveSet(joystickGetAnalog(1,2));
		else
			rDriveSet(0);
		delay(25);
from GitHub - Highway-Man/ALBA-OSSR: ALBA's Open Source Starstruck Robot
What is the abs doing in your code?
It’s a deadband, so if the joystick is between -5 and 5, the motors get set to 0. This prevents the motors from making a high-pitched whining when the robot is on and not moving.
That part of the code checks if the joystick is between -5 and 5 and doesn’t power the motor with those low values. It is a deadband to stop the motors from getting power that you don’t mean to send.
Cool! Thanks for helping me out, I really like pros so far.
Thanks a ton, that really cleared things up for me.
Does this work for V5 as well?
