Can you help me get my Voltage variable changing because before i added the LCD Display Code Chooser i was able to see the voltage change instantly but know it doesn’t
nleos.zip (3.09 KB)
It looks like you have two nested while loops in the driver control part of your code. The second while loop will continue to run, your battery monitoring code is outside of this. Try removing the while loop at line 309 (and also the delay at line 304, that’s not needed)
287 while(true) // An infinite loop to keep the program running until you terminate it
288 {
289 clearLCDLine(0); // Clear line 1 (0) of the LCD
290 clearLCDLine(1); // Clear line 2 (1) of the LCD
291 displayLCDString(0, 0, "Primary: ");
292 sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V'); //Build the value to be displayed
293 displayNextLCDString(mainBattery);
294
295 string expanderBattery;
296 //* Expander Battery Displaying *//
297 if(SensorValue[Power]<2240){ //If Expander Battery is below 8V (2240 Value)//
298 clearLCDLine(1); //Clear LCD line 1 (Bottom Line)//
299 displayLCDString(1, 0, "Exp. Low: "); //Display Expander Low//
300 sprintf(expanderBattery, "%1.2f%c", SensorValue[Power]/280.0, 'V'); //Build the value to be displayed//
301 displayNextLCDString(expanderBattery); //Display the string "expanderBattery"//
302 }
303 //Short delay for the LCD refresh rate
304 wait1Msec(100);
305
306 SensorValue[rightEncoder] = 0; // Set the encoder so that it starts counting at 0
307 SensorValue[leftEncoder] = 0; // Set the encoder so that it starts counting at 0
308 //Loop Forever
309 while(1 == 1)
310 {
311 //Remote Control Commands
312 motor[frontRight] = vexRT[Ch3]+ vexRT[Ch1];
313 motor[backRight] = vexRT[Ch3]+ vexRT[Ch1];
314 motor[frontLeft] = vexRT[Ch3]- vexRT[Ch1];
