I was working on our robot and the wiring isn’t great, especially from the battery to the brain so eventually the outer layer of the battery tore. I read rule R8 in the manual but I’m not sure if the battery connection cable would apply since I think they are talking about motor connection cables.
I wanted to use electrical tape, thats why I referred to R8.
If the battery cable is damaged the best solution is to replace it with a new one.
Check R15, the only exception for using electrical tape for repair is for 2 and 3 wire cables.
Check R6, a damaged battery cable could be a safety hazard.
