Best intake gear ratio?
I am currently using blue motor direct but I was wondering if anything works better
A blue motor is good enough. Just make sure it properly grabs rings (And maybe provide an image?)
It depends on how fast your gear ratio is. If you have a very fast gear ratio, then you should use red motors. If you have a very slow, but strong gear ratio then you should use blue.
