Best position for V5 Radio
My radio signal is keep getting disconnected. Any advice on this will be helpful.
put it on the outside of the robot. make sure it is not enclosed or blocked by anything. also can I see where it is now to get an idea where it would be better. we had this problem last year and we moved our radio to the top of the robot. it helped immensly
The high position definitely helped. Thank you.
Also, many disconnections come from the cable being used. It’s got to be the most rock-solid thing on your robot.
I would recommend keeping the radio slightly inside the robot because the way it seems in the photo looks like it could get damaged or broken.
yea maybe not breaking the plane of the back of the robot
good point. Thank you
