If someone could theoretically do everything possible, what is the best score someone could achieve and how would they do it? I think it would be by getting all of the cubes, except two of each color stacked in the scoring zones, then putting those remaining in the towers. I saw a brief post about this, but it didn’t go into any detail. It said that the best possible score is 202.
finally, what do you think is the realistic? that score of 202 requires 6 stacks of 10 which is an awful lot. I would be very impressed if someone could even fully utilize two colors.
it wouldn’t require 6 stacks of 10, because you can’t make 6 stacks
In skills, sure you could. The larger scoring zones are big enough for 2 cubes side-by side, so in a skills match there is enough room for 6 stacks between all 4 zones. Though I think it’s unlikely that there will be enough time to score all 54 non-placed cubes in 1 minute. Maybe some of the top-level VEXU teams will get close, since they get to use both robots at once in skills this year.
The best possible competition score is 202. The best robot skills score is actually 432. You can check RSC2 in the appendix B to see why.
That’s the best driver skills score. Auto skills is assumed to be the same, though it needs to be clarified, which would come out to a robot skills score cap of 864.
I think it is safe to say nobody will be reaching an 864 skills score
Not with that attitude
You just have to believe in yourself.
