What specific type of string do you guys recommend for a string launcher? I’m pretty sure the best things to look for are cheap, strong, won’t fray, and just heavy enough to lay completely flat on the field. Idk if I should go to my local hardware store or get something like paracord online (is paracord overkill?).
the rule book says you need to use nylon string at 1/4th in thickness or lower
Yeah but like what type of nylon string 1/4 in thickness or lower? It also never says nylon so material and exact thickness is part of my question.
We are using vex made string
the rules used to specify nylon string only a few years back, but it has been changed to allow for all types of rope/string.
So no, you definitely do not need to use nylon string, though it isn’t a bad option.
