So I read through the rule book, and came across a little problem:
Question: Can I sit in my opponent’s protected zone and block them from scoring?
This may seem like an obvious no, but hear me out.
Rule basically says you can’t mess with anything in the opposing alliance’s inner protected zone, and you can’t touch an opposing bot when they are fully in their protected zone.
Rule says you can’t force an opponent to break a rule.
See the problem here? What if a team tries to block, but gets pushed into the goal zone?
Edit:
I’m not sure, but I think rule may solve this problem. (Offensive Robots get the “benefit of the doubt”)
I am in the process of reading through the rules, but I think in this case if I am going to score a cube and you are in the way and won’t get out of the way, I am going to plow through you (think QCC2 v VCAT Skyrise for visual example).
Offensive robots get the benefit of the doubt - When you try to defend them and they push you into the zone, you are trying to force them into breaking a rule (being in contact of the zone). You are also obviously defending, which means that it’s highly likely that you will be called at fault.
(we had the issue this year with the 18" height limit and 2381C’s blocker).
As small as the scoring zones are, I think that it will be necessary to fully utilize the towers to maximize your points, while simultaneously minimizing your opponent’s.
Wallbots, while they often are the most effective defensive robots, may not actually be the most effective way to play defense.
