Brain and Controller aren't connecting wirelessly
Once I disconnect the smart cable that connects the brain to the controller, the controller says that I didn’t link it to the robot and a red screen pops up. The radio for both my controller and the brain are bluetooth. How should I connect both together wirelessly? Thanks.
I assume this is V5, you posted in IQ, I will move the topic.
Do you see the tether symbol on the controller screen when tethering (top line, where radio signal level usually is) ?
What do the LEDs on the brain radio show ?
Does VEXnet work ?
If you can borow another teams controller and see if it is a controller problem or a brain problem.
If it is a brain problem make sure youre radio is connected by clicking on the devices section.
Thanks for replying! I actually realized that I just didn’t plug in a small robot radio sensor, so now it works perfectly fine. Thanks again for your time.
