Brain Connection Issue
I use a MacBook for my programming. I’ve recently come across a problem that involves my brain not connecting to my computer. The message that my brain is connected shows up, but the brain itself won’t connect. Also, sometimes the previous message won’t show up either. I’ve came to the conclusion that there’s something wrong with either my brain, my Mac’s USB ports, or VexcodeV5. Itself. I’ve done every firmware update and that hasn’t fixed my issue. Any help would be appreciated.
Have you tried all the simple things ?
A different cable.
A different USB port
Completely turning off the Mac (shutdown, not just restart)
Yes, I’ve tried all three. I can try more cords but the other two are non-issues.
ok, does the brain show up in system information ? You should see this.
I’m using a different mac right now and once I have access to my bot I’ll check
