When I use the ‘Calibrate Brain Inertial’ block, the robot just freezes. It stops running code, as if it’s stuck on that one block (maybe it is), if you have the problem or have a solution, please help
No solution but we’re experiencing the same thing. Calibrating via the code block takes forever. Manually calibrating from the brain menu takes seconds.
I honestly don’t know why but when we experienced that problem, we took the block out, downloaded the code, ran it, and then put the calibrate brain inertial block back in again it started working without a problem.
Is your air pump running?
Yes, despite there not being a block in the “When Started” section telling it to do so.
You think it’s the vibrations causing the issue?
It’s probably in your drivebase so it calibrates automatically. That would cause the issue but I thought that problem was fixed already. I would think that if you can’t get it to stop to unplug your pump until the calibration is over.
