Does anyone have an issue around their inertial sensor constantly changing values even when the robot is not moving?
We have been facing accuracy issues with our robot when we use Turn blocks (left, right or heading to X degrees) and wondering if this is a sensor issue.
Attached video for more info
make sure the robot is perfectly stationary when the inertial sensor calibrates (ie. when you call calibrate in your code)
This is in driver mode not autonomous
Why would that matter ? If the robot is not stationary when the IMU calibrates it may drift. Try a manual calibration from the devices screen and check the IMU is ok.
Thanks. I checked in the devices screen and the IMU is okay.
So my takeaway is that, even in Driver control, it makes sense to calibrate brain inertial.
Curious though on why teams would use direction blocks in a driver control mode. Am I missing some benefits of using the inertial sensor in driver control mode?
…and Happy birthday. Thanks for taking the time to respond on a busy day
Seeing similar issue, the robot is completely stationary and run a calibrate:
brain_inertial.calibrate()
while brain_inertial.is_calibrating():
sleep(50)
brain_inertial.set_heading(0, DEGREES)
After the calibration, see the heading drifting lower, with no robot movement and just air pump turned on the drift is about 3 degree per minute to counter clockwise. We could compensate if this was constant. The drift increases if the robot is moved.
