Brain new version
hi
so basically our brain usb connection doesn’t work anymore and we have to upload the new version 1.1.3
are you running 1.1.2?
Check in at the Technical Desk at Worlds, they should be able to help out.
It is possible to update via a tethered controller using the VEX VSCode extension, but I would take Pascal’s advise at this point and just come to the software support desk and ask for help prior to going to your division for inspection. Ask for me (James).
venue maps were posted earlier this week.
software/tech support is here.
There is a way to update the firmware through a tethered V5 Controller using the VSCode extension. @jpearman might have some instructions.
1.1.3 was released two months ago.
I think as @Yasou45 is an international team, it would be best for them at this stage to just have tech support do this first thing on Thursday morning at the venue.
Update via a tethered controller is fairly simple, all you really do is manually ask for update via the VSCode command palette, but because the update will take several minutes it can fail (think intermittent cable, battery dies etc.) They may end up with a non-functional robot causing them even more stress.
