Brain not letting Upload code
My brain currently is running code fine connecting to radio and everything fine but me, another team member and mentor cant upload code at all 3 different laptops all confirmed functioning cables and usb c adaptors we tried on sister team brain weve tried restarting laptops brain updateing vexcode (it says its up to date|) switching battery switching battery cable and i dont wanna try restarting brain fully (scared ill loose functioning brain) anybody have anything to try we also tried both python and scratch blocks
Can you elaborate and describe the problem, is it getting stuck mid download, just not letting you download through the program, or what. Are plugging in and trying to download through the controller, or are you using a direct connection to the brain.
ive tried both controller and brain and it just wont pop up to let me download on either
figured out the brain problem the pins are broken but doesent explain the controller not allowing uploades
Can you check the controller pins? Are you connecting the controller to the computer using a USB cable? If you are, try attaching one end of a wire to your brain, and the other end to your controller. That should ensure a direct connection for when you download, as long as you connect the controller to you computer within the coding software.
