My brain when I download a second code, it erases the other one. Is it because my PID has lots of storage needed?
Thanks
Thanks
Do they have different names? Is it a V1 or V2 brain? Can you show us the program selection screen with the first program loaded and then the second?
It is a V2 Brain. the Autonomous is around 50KB i believe, drive code 19KB. basically when i upload lets say Autonomous to the brain with the “DRive code”, Autonomous will be the only one and vice versa
Are you selecting a different slot before you download the code? You’re probably using the same slot for both programs, which will overwrite whatever was in the slot previously.
See this article, is this what you are doing?
Thanks so much, I didn’t see the “Slot”
