So just today, I turned on my VEX IQ Brain, and the brain’s screen was frozen. I pressed buttons on the brain, yet nothing happens.
Brain Info:
Brain Generation: 1st
Brain Info:
Does it have an external power source?
no, it’s just powered by the normal iq battery.
Are you able to take the battery out?
Yes. That is the only way to also turn it off.
Is there a red light shining in the brain?
nope. not one. Just green, that’s all
Try taking out the battery and put a new battery that is at full charge. If that does not work try looking for a small hole that seas reset. You might need to use a small object to push it
ok, mis-information here. There is no hole labeled reset, do not start poking things inside the IQ.
O sorry I thought there was an external reseat button
Does the screen display anything ? or is it just white ?
Can you enter the bootloader (hold down up and down buttons, then power on the brain using the check button).
Guys, the problem’s fixed.
