Brake Hold Toggle
I’ve coded our team’s bot to set the motors to brake type hold to avoid being pushed if the driver presses the down arrow button, but I can’t figure out how to make it stop holding either when the driver lets go or presses it again, like a toggle. This is my code so far, but it would prevent the bot from being driven:
if (Controller1.ButtonDown.pressing() == true) {
      if (holdToggle == false) {
        holdToggle = true;
      } else {
        holdToggle = false;
if (holdToggle == true) {
      Fl.stop(hold);
      Fr.stop(hold);
      Bl.stop(hold);
      Br.stop(hold);
    } else {
      Fl.stop(coast);
      Fr.stop(coast);
      Bl.stop(coast);
      Br.stop(coast);
note the brain screen update thread was just while i was testing it.
this might help, replace the boolean assignment with brake /velocity code for your motors.
bool go = true;
int updateBrainScreen(){
    while(1){
        Brain.Screen.setCursor(2,0);
        Brain.Screen.clearLine();
        Brain.Screen.print(go);
        vex::this_thread::sleep_for(500);
    return -1;
void brakePress(){
    go = false;
void brakeUnPress(){
go = true;
void test(){
myController.ButtonUp.pressed(brakePress);
myController.ButtonUp.released(brakeUnPress);
    vex::thread brainUpdateLoop(updateBrainScreen);
The logic looks like it should work, I think the problems is that the stop function sets the motor speed to zero. I think the function you are looking for is setStopping, which doesn’t stop the motor but tells it how to behave when it does stop.
