Brand New Blinking Batteries. Help
Hey,
My school just purchased two VEX IQ Classroom bundles. I had the students pull the batteries, chargers, and charging cords from the kits so that I could charge them. I have two shock protectors and I plugged in half of them to the protectors.
At first, they were all red to indicate that they were charging, but then they started to blink green. I switched off the power since that meant they were overheating. When I turned the power back on, they all blink red.
At first, I thought it was maybe a faulty battery… but could all of the batteries be faulty from both kits? That seems a little extreme. I unplugged one and plugged it into the wall thinking it was the protector… no dice: still blinking red.
Have I messed up and entire kit of batteries? What make them overheat in the first place?
Just flagged my post I thought you were referring to V5 here are some resources for IQ
Yeah. I’ve seen this page. I tried to figure out what the issue was before coming to the forum, but that doesn’t really tell me why this is happening or what the issue is.
I’m trying to figure out if I’ve rolled a Nat 1 on every single battery or charger in both brand new classroom bundles being bad (because they’re all blinking red now) or if I’m doing something wrong.
Is there a reason new batteries will overheat (blink green) and then blink red after cooling down that isn’t due to the battery being bad?
I put one of the blinking red batteries into a brain and it turned on and said it was fully charged, so now I’m now I’m more confused. Could it be a fault with the chargers or should I just stop worrying and go one with my life?
Have you tried plugging the battery into the brain… and the blink lights on the charger can sometimes act up so see if it works in the brain
You have something weird going on. Reach out to [email protected] and talk to them.
Just received IQ Super Kit and am charging battery for first time. Switched from red (charging) to blinking green (overheat) in a cool (65 degree) room with plenty of clearance all around for proper ventilation. Came here to see if this is common or an indicator of faulty battery and/or charger.
I’ve see this before, the battery will recover.
Take it out, lay it on the table. Slowly say “VEXIQ is cool” five times and plug it back in.
If it goes back to blinking green, put the battery into a robot and drive it for 10 mins and then charge. (So drive like both base motors the length of your build space and back. Over and over. Move the arm and claw while you drive) If you then get a blinking green, call support and send it back.
