If I set a breakpoint,
Run the code until it stops at the breakpoint,
remove the breakpoint and click on continue,
it still stops at the breakpoint. the only way to allow it to continue without stopping is the right click and select ‘Remove all breakpoints’
I was able to test and confirm this 3.54; removing breakpoints while using a physical Cortex still results in the code stopping at the breakpoint. Thank you for making us aware of the issue, we should have a fix out in the next available update.
