I am wanting to create “Functions” or “Subroutines” in VEXcode to segregate some of the code. For example I would like to create a Initialize routine and “call” it right after (when started). I have thought that either using a (broadcast and wait) or creating a My Block. I know either would work, but I am wondering if one would work better than the other, maybe being more efficient with memory or timing. I don’t really need to pass parameters. TIA
I would recommend using a custom block as broadcasting and waiting might use more resources then simply using a my block. Also, with broadcasting and waiting, you would have to use another broadcast to ensure that it would work(wait until). So, the my block is probably going to be the best.
Thanks for your recommendation. This is what we will go with.
