Build Quality!
NO KEPS NUTS!!! Just use thin nylocks
I really like keps nuts with blue locktite
Yea that is fine too
Putting the same number of motors on each side of your lift. rip @6671X
Another thing I see a lot of new teams doing is use plates and bars where a c-channel, angle, etc should be used. (Although there may be scenarios when the may be acceptable.)
For example, using a plate in place of the 5-wide on the chassis in the attached image would be less efficient imo
Bearing + Screws = Magic
=What every good team does to ensure a good chassis.
Today we were walking to a match when both axles fell out of a c channel causing the channel to fall on my foot. Fixed in 2 minutes and put lots of loctite on all the shaft collars during lunch.
Someone said perfect wiring…
2900D
Still unnecessary and horrendous to fix at a comp
while it is true. Its so nice…
The wiring is perfect but you DIDNT CLIP THE ZIPTIES. Sorry it just bothers me a little
Eh not rlly, those are just extensions there. And the wiring is planned out and spread out that I can take out any connection and put it back together in mins.
Took that pic when it was still work in progress.
Perfect wiring?
https://vexforum.com/t/answered-heat-treatment/17944/1
Perfect building, perfect metal, perfect everything here (and everything he builds) from Mr. Pearman.
