My team was trying to build our over under field since it has arrived to us but it only loads sometimes and other times it asks for a passcode. Does anyone know why it does this and how to get the instructions. I attached the photo on what it shows
Are you using the direct link? Or the link.vex?
Make sure you use the latter whenever possible, as it will always redirect you to the most up-to-date version.
I was using the qr code on the box that the elements are in and i also tried the links posted on the forum page for all documents
Thank you so much, that is perfect.
Ah, I see what the issue is. QR code should be fixed now!
