ok, the code has many issues, and I have to work today so have no time to try and fix all of them for you.
fundamental issue was that after the powerSettings button is pressed, you setup the new screen and then exit the CheckCollisions function, that button will not be checked again. I added some debug code to help determine what was going on.
int button::CheckCollisions() {
int count = 0;
printf("CheckCollisions entry %d %08X\n", (int)this_thread::get_id(), this );
while(true) {
// wait for no press
while( Brain.Screen.pressing() ) {
this_thread::sleep_for(20);
// wait for press
waitUntil( Brain.Screen.pressing() );
printf("press %d %d %d %d %s\n", count++, this->s.x, this->s.y, isDisabled, this->text1 );
point p = {Brain.Screen.xPosition(),Brain.Screen.yPosition()};
if (checkCollsion(p, this->s) && isDisabled != true) {
printf("%s pressed\n", this->text1);
if(hasSender)
printf("exit here 1\n");
this -> senderFunctionPointer(senderArgs);
return EXIT_SUCCESS;
printf("exit here 2\n");
this -> functionpointer();
printf("exit here 3\n");
The original code also was constantly running the loop when a button was pressed, so I added code to make sure button (well, screen touch) was released.
but there are other more fundamental issues that I’m not sure how to diagnose just yet related to task/stack use and the way you are creating them on the heap. Not sure how the std::function you create using new is destroyed and how that will conflict with the internal vexos scheduler.
Every button/UI class I’ve created uses only a single task for button monitoring, I really don’t think you should go down the path of having a task per button that monitors for screen presses, my gut says this will just cause more and more problems for you.
The UI class I created for the field control application has the following class hierarchy
Top level UI class that is subclass of vex::brain::lcd
(so it can use those member functions) that has a list of “pages” with one page designated as the current displayed page. There are a bunch of functions to manipulate pages and static member functions for dealing with screen press and release.
A “page” has a number of on screen buttons, a button being a class with an on screen area as well as many other properties dealing with how it’s drawn etc.
The screen press static member function looks like this and is called every time the screen is pressed (ie. it was registered using pressed function on the lcd class )
void
ui::_screenPress( void *arg ) {
if( arg == NULL)
return;
ui *instance = static_cast<ui *>(arg);
if(!instance->_enabled)
return;
int xpos = instance->xPosition();
int ypos = instance->yPosition();
if( instance->_fullscreen )
ypos += 32;
for ( auto &b: instance->_current_page->_buttons) {
if( b.inside( xpos, ypos ) && b.enabled ) {
if( b.toggle == true )
b.state = (b.state == true) ? false : true;
else
b.state = true;
b.pressed = true;
if( b._redraw ) {
b._redraw( b );
if( b._action ) {
b._action( b );
return;
without getting into all the details, it iterates through all buttons on the current page to see if the press was inside the area that defines the button on screen. If it is, actions and redrawing are performed. There’s a similar function for screen release. If a page is not active then no buttons for that page are tested.
So ultimately it’s up to you how you want to implement any of this, but my advise is use the Brain.Screen.pressed and Brain.Screen.released events rather than creating a new task per button.
