Button Latch Help
When I programmed in Robot C, We had a program for a button latch where for example, if I press ButtonL1 once, the motor starts and if I press it again, the motor stops. I understand how the program works, I just cannot figure out how to translate this to vex code. No matter what I try, syntax is not correct.
In Robot C it looked like this:
task usercontrol ()
bool buttonLatch =0;
while (true)
if(vexRT[Btn7L] ==1)
delay(10);
while(vexRT[Btn7L] ==1);
buttonLatch = buttonLatch ^ 1;
if (buttonLatch == 1)
motor[port8] = -80;
else if vexRT[Btn7U] == 1)
motor[port8] = 127;
else if vexRT[Btn7D] == 1)
motor[port8] = -127;
else
motor[port8] = 0;
