Button Toggle - Vex Code
Hope y’all are well.
I have been struggling with turning the button into a toggle for way too long now in vex code.
What I’m wanting to do is press a button turn on a motor. Press the button again turn motor off.
Basically like a light switch.
In robotC that looked like this:
task main()
while(true)
untilBump(bumpSwitch, 300);
startMotor(leftMotor, 100);
stopMotor(leftMotor);
I need to be able to count now. I don’t understand that process. If someone could help me out it would be very much appreciated.
bool toggle = false;
if (Bumper.pressing){
if (!(toggle)){
toggle = true;}
else if (toggle){
toggle = false;}
while (Bumper.pressing){
wait(1, msec);}}
if (toggle){
motor.spin();}
else if (!(toggle)){
motor.stop();}
Here is what I have using your program. I’m still not successful. Is there anything you see that would be causing an issue? All my ports are in the correct location and tested using a working program.
int main(){
vexcodeInit();
if (BumperA.pressing()) {
if (!(toggle)) {
toggle = true;
else if (toggle) {
toggle = false;
while (BumperA.pressing()) {
wait(1, msec);
if (toggle){
leftMotor.spin(forward);
} else if (!(toggle)) {
leftMotor.stop();
All that code needs to be placed in your main control loop, it doesn’t work if you just run it once.
You do need a while loop around the whole code so it continues to run the program. I think that you also need a latch to prevent the toggle from flipping back and forth over every loop.
int main(){
vexcodeInit();
bool latch = false;
while(true){
  if (toggle){
  } else {
    leftMotor.stop();
    if(!latch){ //flip the toggle one time and set the latch
      toggle = !toggle;
      latch = true;
  } else {
    //Once the BumperA is released then then release the latch too
    latch = false;
  wait(20, msec);
Yes! it works! Thank you so much!
all that should be in a while(1) loop
i added the wait while button is pressing so it doesn’t flip back and fourth
