Buttons Don't control arm?
Hey, thanks for reading my question.
When I try to control a motor via the buttons on the remote, the motor does not work. I must have somehow made a spectacular mistake in the way I am programming them. I have isolated the contraption in a short (10-line) program, and for some reason the arm does not move when the buttons are pressed or held. I tried switching the control over to the joystick channel and the arm moves, so I’m not gonna blame my hardware. In addition I tried two different controllers as well as multiple different button layouts, all to no avail. Is there an adaptation I have to make for button controls?
Following is my isolated code:
task main(){
	while(true){
		if (Btn6U){
			motor[rightArm] = 100;
			motor[leftArm] = 100;
		else if (Btn6D){
			motor[rightArm] = -100;
			motor[leftArm] = -100;
		else{
			motor[rightArm] = 0;
			motor[leftArm] = 0;
You have to write vexRT[Btn6U]==1
Yeah… You’re right. I’m dumb thanks
You can simplify what newbievex said by doing
if(vexRT[Btn6U]){
    //stuff
