C++ Gyro
Does anyone know how to code a gyro? We are using it to measure our turns
It is just like any other sensor, you can use the sensor value statement to use for the code. 3600 is 360 degrees
ok. How do you make it where the robot chassis rotates until it reaches a certain degree?
In a while loop,
while(Sensorvalue(gyro) <900)
Or you can get really precise with pid
We tried what you said and it didn’t work.
2.0 RFP.vex (9.5 KB)
He is using VCS, not RobotC.
Jack202020, we tried that and it didn’t work. Thank you for helping and we appreciate the time for trying to help. If you
The program he gave you is in robot c and you are programming in vex c++ so you should actually use
while(gyro.value(rotationunits::deg) <900)
Did you try what I suggested on your other post, here? VCS C++ Gyro Help!! - VEX Coding Studio Tech Support - VEX Forum
Please only make one post per issue
