Hello, I keep getting an error in VCS compiler, but it does not show what is actually causing the error itself. The error is posted below.
Thanks in advance.
indent preformatted text by 4 spaces
21:40:13 -- info -- tar '967A 2.11.0.vex' succesfully extracted to:
C:/Users/michael.oconnor.19/OneDrive/Desktop/Robotics Code/VCS/
21:40:57 -- info -- changed directory: C:/Users/michael.oconnor.19/AppData/Local/VEX
Coding Studio/VEX Coding Studio/sdk/user/
21:40:57 -- info -- C:/Users/michael.oconnor.19/AppData/Local/VEX Coding Studio/VEX
21:40:57 -- info -- file removed: C:/Users/michael.oconnor.19/AppData/Local/VEX Coding
Studio/VEX Coding Studio/sdk/user/cxx.o
21:40:57 -- info -- clang version 5.0.1 (tags/RELEASE_501/final)
Target: thumbv7-none--eabi
Thread model: posix
InstalledDir: C:\Program Files (x86)\VEX Robotics\VEX Coding
Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\bin
"C:\\Program Files (x86)\\VEX Robotics\\VEX Coding
Studio\\node_modules\\@modkit\\modkit-compiler-binaries-
windows\\clang\\bin\\clang.exe" -cc1 -triple armv7-none--eabi -emit-obj -disable-free -
disable-llvm-verifier -discard-value-names -main-file-name cxx_entry.cpp -mrelocation-
model static -mthread-model posix -mdisable-fp-elim -fmath-errno -no-integrated-as -
mconstructor-aliases -nostdsysteminc -target-cpu generic -target-feature +soft-float-abi
-target-feature -fp-only-sp -target-feature -d16 -target-feature +vfp3 -target-feature -
fp16 -target-feature -vfp4 -target-feature -fp-armv8 -target-feature +neon -target-
feature -crypto -target-feature +strict-align -target-abi aapcs -mfloat-abi soft -v -dwarf-
column-info -debugger-tuning=gdb -ffunction-sections -fdata-sections -coverage-
notes-file "C:\\Users\\michael.oconnor.19\\AppData\\Local\\VEX Coding Studio\\VEX
Coding Studio\\sdk\\user\\cxx.gcno" -nostdinc++ -resource-dir "C:\\Program Files
(x86)\\VEX Robotics\\VEX Coding Studio\\node_modules\\@modkit\\modkit-compiler-
binaries-windows\\clang\\lib\\clang\\5.0.1" -D _LIBCPP_HAS_NO_EXCEPTIONS -D
_LIBCPP_HAS_NO_THREADS -D VexV5 -I . -I ../clang/7.0.0/include -I ../vexv5/include -I
../vexv5/gcc/include -I ../vexv5/gcc/include/c++/4.9.3 -I
../vexv5/gcc/include/c++/4.9.3/arm-none-eabi/armv7-ar/thumb -I ../modkit -internal-
isystem "C:\\Program Files (x86)\\VEX Robotics\\VEX Coding
windows\\clang\\lib\\clang\\5.0.1\\include" -internal-isystem include -Os -Wno-unknown-
attributes -Werror=return-type -Wall -std=gnu++11 -fdeprecated-macro -fdebug-
compilation-dir "C:\\Users\\michael.oconnor.19\\AppData\\Local\\VEX Coding
Studio\\VEX Coding Studio\\sdk\\user" -ferror-limit 19 -fmessage-length 0 -fallow-half-
arguments-and-returns -fno-rtti -fshort-enums -fno-signed-char -fno-threadsafe-statics
-fobjc-runtime=gcc -fdiagnostics-show-option -vectorize-loops -vectorize-slp -o cxx.o -x
c++ cxx_entry.cpp
clang -cc1 version 5.0.1 based upon LLVM 5.0.1 default target i686-pc-windows-msvc
ignoring nonexistent directory "C:\Program Files (x86)\VEX Robotics\VEX Coding
windows\clang\lib\clang\5.0.1\include"
ignoring nonexistent directory "include"
Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\lib\clang\5.0.1\include"
#include "..." search starts here:
#include <...> search starts here:
../vexv5/include
../modkit
End of search list.
21:40:57 – info – make process failed with return code: 1
