I’m having problem with a c++17 and I’m not very good at programming so any help would be nice
Do you have a specific problem or are you looking for good resources to learn c++?
I have a specific problem.
Firstly it looks like you are using robotC (am I right because you mark the question as Vex coding studio). Also Yellow exclamation mark looks like it is a warning (not sure) and would not cause any errors. Then in the if statement you are missing a )
it should be…
if(vexRT[Btn6U == 1])
Also next time please put all the information in the thread and explain your issue well.
ROBOTC syntax in VCS is not supported.
that is, you cannot use motor[] and vexRT[], there is a new API.
http://help.vexcodingstudio.com
