C++ Vex v5 cannot use function
#include "vex.h"
using namespace vex;
int write(char text) {
  Brain.Screen.print(text);
  Brain.Screen.newLine();
  return 0;
int main() {
  vexcodeInit();
  Drivetrain.setDriveVelocity(100, percent);
  //Drivetrain.drive(forward);
  int creller = write("Test");
This gets me the error by write:
No matching function to call ‘write’
How can I fix this?
Your function write takes a char which is a single character:
https://www.learncpp.com/cpp-tutorial/chars/
You probably want write to take an std::string instead:
https://www.cplusplus.com/reference/string/string/
You need to define write as:
int write(const char* pText)
   Brain.Screen.print(pText);
   return 0;
because compiler sees “Test” as const char*
Then everything should work.
I’m assuming that you meant “text”
